Engine is burning slight Oil
Old Mar 28, 2006 | 12:57 PM
Visheetal's Avatar
Visheetal
Default Engine is burning slight Oil
I have a honda civic 95, mileage 140k and expereincing a strange problem. I go for regular oil changes. The oil presuure gets low after every 200 miles, and I have to refill the oil. There are no leak spots where the car is parked, at home or in office, there is no smoke or smell that might give a hint of burning of oil. I took it to Jiffy Lubes and they suggested that the oil might be leaking from rear main seal or oil pan case gasket might need to be replaced. I showed it to 2 mechanics and they confirmed that the oil is burning.
I donot have any idea what should I do. Pointers are welcome.
Thanks
Visheetal
Old Mar 28, 2006 | 01:23 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Thanks
Visheetal
Is it burning or not?...Umm every 200 miles I think you might have a leak...I dont think you can burn that much oil in 200 miles...You say you dont see any leaks?
Old Mar 28, 2006 | 02:08 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Do a compression and leakdown test. That will tell you where to go from there.
Old Mar 30, 2006 | 07:23 AM
dpkelly's Avatar
dpkelly
1999 Civic Driver
I'm burning a quart per week and drive 40miles a day to/from work. My compression measured 120psi and the minimum spec is 135psi. Suffice to say I'm burning it but it burns cleanly or gets trapped in my CAT. Go with a thicker oil like 10w30 or 10w40 when it warms up. That's what I do.
Old Mar 30, 2006 | 07:55 AM
raiden571's Avatar
raiden571
turning u inside out
just replace the rings and rehone the cylinder walls, u wouldnt even have to take the motor out. just drop it all from the bottom with the head off
Old Mar 30, 2006 | 10:00 PM
VTechSol's Avatar
VTechSol
Black 93 Del Sol Si
yea with 140k your rings might be getting bad, so its probably burnin oil
Old Mar 31, 2006 | 08:59 AM
raiden571's Avatar
raiden571
he just said that
