need help removeing o2 sensor
Old Mar 7, 2006 | 03:53 PM
fat tony123's Avatar
fat tony123
Default need help removeing o2 sensor
trying to remove old o2 sensor on 94 civic ex, nothing seems to work tried heating up, lube, everything. took to a shop they couldnt remove either. any ideas?
thanks
Old Mar 7, 2006 | 05:03 PM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
I had the same problem on mine, when I was in the process of transfering the O2 sensor from my oem manifold to my dc one. I sprayed some rust remover/loosener on it first. I had the wrench on it, and I put my weight on it with my foot, and after a few light hops/kicks, it came loose. Then I transfered it with the O2 extension that came with my DC and it was fine. It was funny, as I tried to have a shop take it out too and they couldn't.
My friend covered the wrench with a shop cloth and started to pound away with a rubber mallet and that worked for us when we worked on his car.
Might want to try that.
Old Mar 8, 2006 | 05:22 PM
mini-me civic's Avatar
mini-me civic
for my o2 sensor i got a wrench.. put a long pipe over it and the sensor came out no problem... be sure to use anti-seize wen u reinstall it so u wont have this problem again...
Old Mar 9, 2006 | 06:25 PM
fat tony123
thanks i will certainly try that.. come to find out the shop where i took it to used a blow tourch.now the manifold is crack so have to give em hell to try to get them to replace that thanks again
Old Mar 9, 2006 | 09:24 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
That sucks. I had a cracked manifold once. Gas in the cabin when the vents were open. Horrible.
Since you know that they did it, file a complaint. The Bureau of Automotive Repair handles stuff like this.
You might have to be the guy that they just FIX-IT for, just to get you to go away.
http://www.dca.ca.gov/complainthelp/...complaint.html
Good luck!
