Exhaust troubles
Old Mar 6, 2006 | 02:23 PM
Troubbll's Avatar
Troubbll
Default Exhaust troubles
I have a '98 Civic EX with 51,000 miles and have replaced the muffler twice, the center pipe three times, and the heat shield has fallen off. I only drive it a few miles most days, and live in Vermont. Is there any way to stop this from happening again??? Will a stainless steel center pipe and muffler withstand the weather better?
Old Mar 6, 2006 | 11:24 PM
Brad's Avatar
Brad
wooo nascar!
stainless >>>> mild. especially in the northeast.
Old Mar 7, 2006 | 09:45 AM
twinring's Avatar
twinring
where I live they dont throw pure salt on the roads since its so expensive, they use beach sand. I recommend you use a high pressure washer on the undercarriage of your car after driving in snowfall.
Old Mar 8, 2006 | 06:10 PM
alanMI88's Avatar
alanMI88
dont drive in snow. take the bus.
Old Mar 9, 2006 | 03:25 AM
DCivic's Avatar
DCivic
The exhaust is not "heating up" enough during your short commute. Condensation inside the exhaust combined with the salt/winter grime is most likely causing your accelerated wear.
Any way to lengthen your drive? ie stop for coffee/breakfast, run some errands, anything to allow the pipes to heat up and burn off extra moisture.
Good luck!
ps I agree that stainless will hold up much better
