Strange beeping, 1999 Civic EX
Old Feb 25, 2006 | 07:37 AM
sgl's Avatar
sgl
Default Strange beeping, 1999 Civic EX
All,
Last night, I got in the car, and everything seemed normal when I turned the key to 'on", except that the car beeped 6 times. Started fine, lamps turned on and then off as expected. But I swear I don't remember the thing beeping 6 times.
Couldn't google anything useful, and the manual doesn't say anything (or at least I couldn't find anything).
I am about to check the factory alarm codes, but I was under the impression that the factory alarm wouldn't go off unless there was a break-in, and everything looks ok. And, of course, it might have nothing to do with the alarm...
Any ideas?
sgl
Old Feb 25, 2006 | 12:31 PM
ReVenGe's Avatar
ReVenGe
how many times does it normaly beep? does it still beep 6? maybe you just fidgeted the key so it went to "on" twice.
Old Feb 25, 2006 | 05:30 PM
97lCivic's Avatar
97lCivic
Are your sure it wasnt from your door being open or not having your seat belt on? Or even headlights?
Sometimes, my civic does that after i first insert the key or start ignition.
Old Mar 1, 2006 | 06:34 AM
sgl's Avatar
sgl
Default The beeping...
Yep, it's exactly 6 times, and normally no beeps.
i think it IS the seatbelt. I've tried the ignition without the seat belt on, and get the same 6-beep sequence. that, after annoying neighbors with the alarm system, trying to figure out if the alarm was the culprit. of course, i can't repeat the problem any more. but, if it's just the seat belt sensor, then there's no real problem, i guess. could have been much worse
Thanks to all!
Old Mar 2, 2006 | 02:51 PM
JTF's Avatar
JTF
could be normal. whenever i start up mine it's beeps six times, but that's just your computer checking safety systems like airbags..abs...etc. i don't think six times is unheard of. might be more of a concern if it didn't stop beeping or some of the system lights came on.
Old Mar 8, 2006 | 04:56 PM
twopointsevenv6's Avatar
twopointsevenv6
Just to 'chime' in...If anyone gets a definite answer on this please let me know. My '97 Accord does this too when I turn the ignition to the "on" position. It's a weird beep, different from door chime/headlights and different from actually cranking the starter then returning to "on" position. No CEL either. ...Sorry for the pun.
