Nitrous advice help me please
Old Feb 15, 2006 | 07:57 AM
heinousmule's Avatar
heinousmule
skeet skeet
Default Nitrous advice help me please
I have a 93 honda civic dx hatchback with a D16Y8 motor, most of my parts are from the 95 civic si, like the tranny and the harness is from a 95 civic si vx model, believe it or not this car runs good. I am thinking of runnin nos but i've heard alot of bad stories that if something was to go wrong like a little pin hole in the line, a person could blow up. Any advice and how many psi would u recommend for me not to exceed.
Old Feb 15, 2006 | 08:41 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Nitrous isn't flamable. It just increases the burn when it reaches the cylinder. Pinhole leaks are easy to notice anyway if you have a PSI gauge on the bottle or in the car. When you open the bottle the numbers won't be where they should. Nitrous can damage a motor but if you run a 55 65 shot, get colder plugs and tune your timing I think one or two degress it will last a lot longer than just strapping a bottle in and hitting.
Old Feb 15, 2006 | 09:13 AM
cobbcustomz's Avatar
cobbcustomz
i have a ZEX system hooked up to my 99 EX. no change in plugs or timing and havent had any issues in almost 3 years
Old Feb 15, 2006 | 09:34 AM
Running925's Avatar
Running925
Your Powder Coater
usage is a big factor here.. can you also state how much you use it or how many bottle's full you have put through your engine.
I personally put 5 bottles through my d16z6 before with upgraded fuel system & plugs & had no problems. Then swapped.
Old Feb 15, 2006 | 09:10 PM
cobbcustomz
yea sorry h: I ran 4 full bottles thru, 3 bottles on the street and 1 bottle at the track
Old Feb 16, 2006 | 07:51 AM
Omniscient's Avatar
Omniscient
I never finished doing nitrous in my car. I couldn't find just the ZEX box and I already had everything else.
Old Feb 16, 2006 | 09:20 AM
Running925's Avatar
Running925
Your Powder Coater
ebay or order directly from zex, usually in the $200 range
