why is my clutch pedal not coming back up
Old Feb 1, 2006 | 01:08 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default why is my clutch pedal not coming back up
when i push it in it stays on the floor. i just finished my clutch and haven't bled the line yet and was wondering if that could be why.
Old Feb 1, 2006 | 01:57 PM
ReVenGe's Avatar
ReVenGe
i dont know much... but is there a spring on the pedal itself? maybe that came unhinged or something
Old Feb 1, 2006 | 02:12 PM
97civicEXVTEC
the master cylinder? i don't think that uses a spring. i was thinking that it was due to lack of presure from the clutch lines.
Old Feb 1, 2006 | 03:42 PM
ReVenGe's Avatar
ReVenGe
whats it feel like when you try to pull up the clutch manualy?
Old Feb 1, 2006 | 03:54 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
It could be hydrolic but it seems more likely that it's mechanical, like say somewhere out of sight. Just my .02
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Air in the lines or fluid levels are low. You may also have a leak.
Old Feb 1, 2006 | 03:55 PM
97civicEXVTEC
if i pull it back up it comes up with next to no effort and it will sit in the normal position. it's just easier then normal to push it down and it doesn't come back up.
Old Feb 1, 2006 | 04:06 PM
ReVenGe's Avatar
ReVenGe
i'd go with asian dude...... doesnt sound like theres pressure then.
Old Feb 1, 2006 | 04:12 PM
97civicEXVTEC
yea thats what i thought. i just did my clutch and hadn't bled the lines yet. i just wanted to double check to see if that was the reason. thanks a lot man
Old Feb 1, 2006 | 04:13 PM
CivicRacr's Avatar
CivicRacr
i agree, lack of pressure, when i bleed the clutch lines, it doesnt spring back up, i have to manualy pull it back up to pump it again
