Auot to Manual Parts
Old Jan 31, 2006 | 07:33 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Default Auot to Manual Parts
What I need is a list of all the parts I will need to do a auto to manual swap on my 93 civic ex. I'm putting a b16a in my car and i need a list of all the parts I need for which car I need it. When I am finding parts, do they all have to be from a 92-95 5 speed or from a b16a engine? Quick responses are a plus..
so far:
pedal assembly $65
hydro lines $60
master cylinder w/ reservoir $60
shift linkage $75
what else?
Also, it possible to put a GSR tranny on a B16?
Old Feb 2, 2006 | 05:05 AM
civic8891's Avatar
civic8891
im pretty sure you can use a gsr tanny on that engine. i know you can on the b18
Old Feb 2, 2006 | 06:15 AM
teg92's Avatar
teg92
WHAT OK YEAH!
yes, you can use the GSR tranny on the b16, you will also need a manual intermediate shaft, slave cynlider, a manual ECU, flywheel, clutch, you might need a starter from a manual car not sure though. Are auto tranny mounts the same as a manual? I think that might be it
Old Feb 2, 2006 | 06:30 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
WSell i think i have everything but the intermediate shaft, where can i buy one of those?
Old Feb 2, 2006 | 07:43 AM
Jafro's Avatar
Jafro
I'm made of meat!
JDM Center Console...
Old Feb 2, 2006 | 08:05 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i have one that i can sell you if you want, if not then you can go to a local junkyard i think there like $100.00, make me an offer if you want ill take some pics of it
Old Feb 28, 2006 | 07:45 PM
Driverman5777's Avatar
Driverman5777
no u need the manual tranny mount
Old Mar 1, 2006 | 06:52 AM
Running925's Avatar
Running925
Your Powder Coater
Hasport auto to manual conversion mount
the bracket that is welded to your passenger side frame rail is not in the same position on manual car as it is in an automatic, there for you will need that swap mount or you will need to cut the bracket & do a nice job welding it to the position that the manual on is supposed to be.
Also, The GSR intermediate shafts are different than the LS ones.. doesn't matter which one u use but it does need to have matching axles.
for example, if your using ls intermediate shaft, you need 94-01 LS axles
btw, not all intermediate shafts are the same.. make sure u get one from a 94-01 teg
Old Mar 1, 2006 | 07:16 AM
hybred-1's Avatar
hybred-1
jdmshit also has a auto to manual mount i think it was 125 shipped
also shift knob and manual center console.
on my swap i also had to change the gas pedal due the the throttle linkage, which you will also need.
i would stick with a b16 due to the gear ratio.
oh and if you haven't changed them yet valve cover gasket, timing belt, water pump, plugs, wires and change oil.
drivers side mount, tranny bottom mount, rear bracket and mount from a 94 -01 teggy or dohc del sol. if these weren't with the motor.
take out the little blue box from the brakes.
Old Mar 1, 2006 | 07:27 AM
vtecb20coupe's Avatar
vtecb20coupe
eh2
when you're ready to buy, shoot me a pm. i've got the clutch master cylinder and pedals.
