in desprite need of answers on my "d16z6"
Old Jan 28, 2006 | 11:05 PM
acedjinhere's Avatar
acedjinhere
Default in desprite need of answers on my "d16z6"
im new so please dont flame me, but what are the specs on the d16z6 . i bought what was described as a 93 dx with an ex ctec swaped in but the dx harness so the vtec was disable to alow smog- does any of this make sence? what do i really have under the hood? block says D16Z6 1100556 and the head is labeled D111270708 then p08-5 and the ecu serial is 37820-pm6-l00 what does all that mean if anything? i am SOOOO confused and i need to know cuz i want to buy mods but dont want to buy the wrong ones for the engine i have. any input will help. thanks
Old Jan 28, 2006 | 11:08 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Does the head have a little bronze cylinder(vtec selenoid) on the back near the distributor? If your block says d16z6, then yes the block is a z6. As for the head, I've never messed around with a single cam so I don't know their head codes. The specs are 127hp and I think 106ftlbs of torque. If your car isn't wired for vtec, you can easily add the wires yourself. It takes about 15 minutes to run the wires to the ecu and solder them.
Old Jan 29, 2006 | 12:35 AM
acedjinhere
yeah it does and there are spliced wires and cut wires and some ghetto a$$ shit done under the hood i will try to get pics but what should i do should i tru to hook up the vtec or just keep it non??
Old Jan 29, 2006 | 12:50 AM
acedjinhere
ok and the ecu i have is the non vtec one what ecu do i need to be able to run my vtec? plus what els do i have to do like hoses or anything?
Old Jan 29, 2006 | 07:50 PM
waaBAAH's Avatar
waaBAAH
no hoses just three wires......and proper ecu. vtec obd1 sohc.
A yellow wire with a green stripe for the vtec solenoid can be found on the engine harness and must be pinned in at A4. The vtec oil pressure sensor can be found as a blue wire in the harness and must go to D6. and then the black is ground.
look in the "sticky" for the proper ecu pinout palcement for the ecu conectors
Old Jan 29, 2006 | 08:02 PM
acedjinhere
ok thanks for the help, on the valve cover the is a hole on the bottor right corner that was pluged by a bolt what goes there??
Old Jan 29, 2006 | 10:16 PM
waaBAAH's Avatar
waaBAAH
ground....you really dont need that but it connects from valve cover to above left front headlight on chassis
Old Jan 29, 2006 | 10:27 PM
acedjinhere
naw not that hole its bigger and doesnt have threads and leads directly into the valve cover??
Old Jan 30, 2006 | 12:10 PM
waaBAAH's Avatar
waaBAAH
valve cover bolt/stud then
Old Jan 30, 2006 | 07:21 PM
raiden571's Avatar
raiden571
turning u inside out
youll need the p28 ecu unless u decide to just chip ur ecu with come or something
