Throttle body problems?
Old Jan 25, 2006 | 10:36 AM
Vundizzle's Avatar
Vundizzle
Default Throttle body problems?
We've recently just put in my new throttle body 68mm and now when we start the car, it has definate trouble and idles 500ish RPM (mostly in the winter time). In order to start it, I need to twist the key, hit the gas just a bit, and rev it at about 1k for a minute or so in order for it not to kill. We've adjusted the cable and it still has a rough time starting up. But when the car gets a little warmer, it starts to idle normally and runs perfectly fine. WTFMATE. Help a noob out! Thanks.
Old Jan 25, 2006 | 11:03 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Turn the idle up a hair, its because it cold out.
Old Jan 27, 2006 | 05:16 PM
JDMPONY00's Avatar
JDMPONY00
it's most likley had an effect on your IAC idle air controll valve, what kind of tb is it.
Old Jan 27, 2006 | 08:07 PM
bambbrose's Avatar
bambbrose
its not the IAC that was effected.
I bet his new throttle body doesn't have a FITV
Old Jan 28, 2006 | 04:53 AM
JDMPONY00's Avatar
JDMPONY00
what i ment is the throttle body probalby doesnt have the IAC valve hole cut in it, causeing the iac not to function properly. when i got my skunk2 68mm tb it had the hole but the gasket it came with didnt, so i had to put a hole in the gasket to to allow the iac to bypass the butterfly like it should fixing the cold start issue and low idle.
Old Jan 28, 2006 | 09:11 AM
bambbrose's Avatar
bambbrose
ah that is true. I didn't think about the hole.
So yea, just check your iacv and your fitv
Old Jan 31, 2006 | 03:58 PM
pghprettie_boi's Avatar
pghprettie_boi
How do you turn the idle up?
Old Jan 31, 2006 | 04:10 PM
bambbrose's Avatar
bambbrose
you should never adjust your throttle screw. Its preset from the factory and the ECU controls idle.
Old Jan 31, 2006 | 04:16 PM
JDMPONY00's Avatar
JDMPONY00
the throttle screw is really just thier to keep your throttle plate from binding, but screw it upwards raising the throttle lever it's located under the thing where the throttle cable attaches to the throttle body. but it might cause your car to surge if you adjust it up.
