brake upgrade fit in 97 gsr rims?
Old Jan 23, 2006 | 04:25 PM
ReVenGe's Avatar
ReVenGe
Default brake upgrade fit in 97 gsr rims?
will a bigger calliper brake...... anykind...... fit inside the 16 spoke acura gsr rims?
File Type: jpg
Old Jan 23, 2006 | 06:11 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
integra calipers will fit, probably itr and nsx
If it doesnt fit, you can most likely just use a 5mm spacer, since it will be the offset that causes a problem.
Old Jan 23, 2006 | 08:25 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
it depends on what kind of big brake upgrade you are going with.
Old Jan 23, 2006 | 10:13 PM
ReVenGe's Avatar
ReVenGe
will i just be able to get bigger spacers untill what ever size caliper will fit? or is there a limit.... like... those bear brake are ginormous.... could i just use spacers untill they clear?
