Overheat Problem!!!!
Old Jan 16, 2006 | 08:00 AM
dohcvtec's Avatar
dohcvtec
Default Overheat Problem!!!!
I Have A 94 Honda Civic Ex D16 Motor....k And N Intake, And A Dc Header...did A Complete Tune Up....change The Thermostat...only Overheated When I Race........
Old Jan 16, 2006 | 08:44 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You shouldn't race then.
Old Jan 16, 2006 | 09:51 AM
Exadar's Avatar
Exadar
Be Quiet and Drive
Learn to type and stop street racing
If you want real advice... check to see if your radiator is leaking...
Old Jan 16, 2006 | 10:33 AM
wicked_geezer's Avatar
wicked_geezer
ur fan probably aint workin check ur fan fuse...u need to stop racing...
Old Jan 16, 2006 | 10:41 AM
R_Squared's Avatar
R_Squared
LEVEL UP
come on guys, maybe he races at the track....maybe.
Old Jan 16, 2006 | 12:26 PM
Jafro's Avatar
Jafro
I'm made of meat!
Maybe his coolant system isn't holding 15 PSI of pressure. Maybe he has a bad head gasket and is blowing exhaust pressure into his coolant system. Maybe a radiator pressure test would fix his problem?
Old Jan 16, 2006 | 04:24 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
That's what happened to me. Pressure building up in the cooling system. Bubbling coolant, and top radiator hose puffy. Car would drive fine for about a half hour, then gauge shot STRAIGHT UP. Not good times.
The dreaded head gasket.
Drive safe, dog!
