changing the filter on my cold air intake
i have a 96 civic with a cold air intake. It came with it when i got my car. what's the easiest way to change the filter since it's in the fender well? also, how often should i change it?
Originally Posted by Jager99
i forgot to mention...without taking off the front bumper. is it hard taking off the front bumper?
this one is cheap. if i do decide to keep the cold air, i'll definitely buy a better filter. I'm afraid of hydrolocking, so i might switch to a short ram. there's no other way to replace the filter? can i remove the fender lining in the wheel well?
on the 6th gen (96-00) civic, it is more than just 2 clips. I'll post pics tonight.
The bumper is easiest way to access the filter, just like people said. But it's attached by:
- 2 screws at the sides right at the pointy part of the bumper in the fender
- 3 10mm-head screws under the front (get down, you'll see them)
- about 7 plastic clips (pop the hood, use a flat head screwdriver to GENTLY pry up the center button, remove the button, then remove the outer plastic)
Then pull the bumper straight forward from the car. I must have done this 6 times by now to access my CAI, horn, add fog lights, etc.
