Modifacation Question
Old Jan 11, 2006 | 08:58 AM
Jaidon05's Avatar
Jaidon05
Default Modifacation Question
I live in Pa and are laws are dumb does anyone know what mods I could do to my 92 honda civic?
Old Jan 11, 2006 | 09:08 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
cold air intake or short ram intake
throttle body
intake manifold
bigger injectors
fuel rail
fuel pressure regulator
header
exhaust
high flow cat
SAFC
VAFC
cams
adjustable cam gears
forged rods
forged pistons
Head gasket
arp rod bolts
arp head studs
spoon valve cover, or maybe mugen?
walbro fuel pump
stainless steel fuel lines
chipped ecu
traction bars
drag radials
skinny rear wheels.
supercharger
turbo
if turbo... intercooler
if turbo... wastegate
if turbo... oil lines
if turbo... blow off valve
if turbo... charge piping with couplers
if turbo... turbo manifold
if turbo... downpipe
if turbo... 3 bar map sensor
if turbo... boost controller
if turbo... boost guage
vacuum block
port and polish
larger diameter valves
valves
retainers
cutout
spark plugs
spark plug wires
coil packs
msd ignition (cap rotor blaster)
lightweight crank pulley
aluminum radiator
silicone radiator hoses
oil catch can
new coolant resevoir
larger master cylinder
Sprung clutch, unsprung clutch
Lightened Flywheel
stroked crankshaft, bored out motor
sleeved motor
block guard
motor swap
if motor swap: b16a
if motor swap: b16b
if motor swap: b18b1
if motor swap: b18c1
if motor swap: b18c5
if motor swap: h22
if motor swap: d16
if motor swap: d15
if motor swap: k20
if motor swap: k24
lip kit
body kit
taillights
spoiler
headlights
corner lights
hood
hood scoop
roof scoop
some mesh grilles
chrome trim
fenders
carbon fiber this
carbon fiber that
tint your windows
stickers
sidemarker lights
thin side moldings
rims
springs/shocks
coilovers
polyurethane bushings
lower control arms
upper A arms
c/d rotors
larger piston calipers
larger brakes
lug nuts
tires
paint
racing seats
guages
cd player
mp3 player
tape player (OG)
equilizer
speakers
subwoofers
amplifier
capicitor
stereo wiring kit
optima battery (batteries maybe?)
floor mats
shift knob
ebrake boot
short shifter
glowing neon pedals
neon lights
color light bulbs
side mirrors
rear disc brake conversion
etc..
Old Jan 11, 2006 | 09:11 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I live in PA what's wrong with the laws? I've never had a problem so far and have been modifying Hondas since 1996.
Autocross Help Page
Old Jan 11, 2006 | 12:36 PM
97civicEXVTEC's Avatar
97civicEXVTEC
:rofl: how long did it take you to type that list
what part of pa do you live in?
