car jerking
Old Dec 28, 2005 | 06:23 PM
dmelhorn's Avatar
dmelhorn
Default car jerking
Ok I have had my car for a year now. It is a 99 civic ex with a 5 speed. I will be driving it and the check engine light will come on. THe code that it is reading is a idle air control vavlve error. Now from what I have read the cars idle should raise and lower when you have a problem with the IACV. But it does not, what it does is every time I touch the gas pedal the car kind of jerks and then it will do the same when I let off the gas pedal. But if I push in the clutch it will not jerk when I let off of the gas and push in the gas.
So I took off the IACV and cleaned it really good. It still did the problem. So I broke down and got a new one for 170 and put it on. It still does it. SO I dont think that it could be the IACV.
It also starts to do this problem and throw the code when I make tight corners like u turns.
Could this have something to do with the transmission or the clutch. It is driving me crazy I just cant find out what is wrong, does anyone know a solution?
Old Dec 28, 2005 | 07:34 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Yes, the code will cause the jerking on and off throttle
(a dirty or poorly functioning iacv will cause idle issues)
Try cleaning the connector with a LITTLE brake cleaner and then put some dielectric grease on it. Take the unit you bought back.
This same problem happened to me about 2months ago and since I cleaned put dielectric grease on the connector, the problem has gone away
Old Dec 28, 2005 | 08:14 PM
dmelhorn's Avatar
dmelhorn
Thanks for the info I will try that.
I did take back the new one and put the old one bakc on.
