clutch pedal feel dropping?
Old Dec 14, 2005 | 06:54 AM
sspire's Avatar
sspire
Default clutch pedal feel dropping?
in the past couple of days the cluch on my civic has been dropping down closer and closer to the floor cluch is still good i know that but what coiuld be causeing this? maybe MC????
Old Dec 14, 2005 | 07:28 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
master cylinder, slave cylinder, or maybe just low on fluid
Old Dec 14, 2005 | 07:57 AM
sspire's Avatar
sspire
ordered an omni power MC, went out side to check fluid and resivoir was dry.... deet de dee.
Old Dec 14, 2005 | 09:59 AM
PDiggityDogg
Ive heard lots of issues with those omni mc's... Id cancel that sale.
You have a big-ass leak. Maybe its from the seals, maybe its from damage, maybe youre line is fried, maybe your connection is bad, maybe the slave cyl has a leak.
Fill it back up with fluid, bleed it, and see where the fluid goes
Old Dec 14, 2005 | 07:07 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Omni cleared up their issues with their bad batch. There should be no problems with their new design.
Old Dec 15, 2005 | 12:39 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
Both of the bad MCs that I saw had a leak that you could see on the inside firewall above the pedal (where the MC is bolted on the other side). Don't for ge to look there for wetness.
Old Dec 16, 2005 | 05:36 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
check the fluid for you clutch. under the hood near the brake fluid.
Old Dec 16, 2005 | 08:53 AM
Kai's Avatar
Kai
Rotorphile.
You didn't check it before buying parts?
Try refilling it, bleeding it, and see if it leaks again.
In some cars, the fluid just disappears. It's happened to me before on a perfectly healthy clutch hydrolic system. It's very unusual though, you'll probably need that new master.
