IACV before and after Carb cleaning
Old Dec 13, 2005 | 09:40 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Default IACV before and after Carb cleaning
Finally uploaded the pics off of my camera. Before and after on the IACV. HIt it hard with carb cleaner. It helped. Up and down idle has stopped. Hope this helps.
File Type: jpg
File Type: jpg
Old Dec 13, 2005 | 10:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That shit was really clogged.
Old Dec 13, 2005 | 11:12 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
Looks great. Thanks for putting that up. I need to take mine off for sure. Did you lose very much water? Any tips?
Old Dec 14, 2005 | 08:44 AM
Chefboiali's Avatar
Chefboiali
scrotal surge
Didn't lose any water. Holly shit.... Was water supposed to be there? I just took a 12mm to undo the two bolts, took off the connector, blasted it with carb cleaner, let it sit in the balcony, and put it back in hours later. The gasket sits flush inside a groove, and was perfect. Just reused it. I made sure I disconnected the battery and started up w/out hitting the gas. (As you should do anyway)
Old Dec 14, 2005 | 09:02 AM
qtiger's Avatar
qtiger
Those two nipples beneath it are supposed to be connected to coolant lines.
If they aren't, that may be why your IACV is so clogged.
Old Dec 14, 2005 | 09:41 AM
Chefboiali's Avatar
Chefboiali
scrotal surge
Hmmm.... I'll check that shit out when I get home. I guess I'll follow the lines and check for any other clogs. Thanks for the tip.
Old Dec 14, 2005 | 01:52 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i dotn like using carb clean, id rather use brake cleaner on those kind of things because carb clean doesnt exaporate as fast as brake clean and carb cleaner is also oil based too.
Old Dec 14, 2005 | 02:07 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
The car had been sitting for a while when I took it out. Previous owner was running car hot. Guess that's why it was all clogged. Thermostat was stuck shut, radiator had a whole in it. It was pretty screwed bad.
Old Dec 16, 2005 | 03:23 PM
honda_civic's Avatar
honda_civic
Default IACV location
i was wondering if anybody has pics of the IACV on the car as i need to locate it to clean it. thanks
Old Dec 16, 2005 | 03:40 PM
honda_civic
does anybody have pics of the IACV when on the car. thanks
