Left brake light not working
Old Nov 25, 2005 | 07:49 AM
5speedonly's Avatar
5speedonly
Default Left brake light not working
Everything else works fine, no exception. I'm still diagnosing it and meanwhile I hope I get some help. The bulb is fine; I switched them and they're working. And it can't be the fuse ....
Old Nov 25, 2005 | 07:53 AM
randomtask77's Avatar
randomtask77
Wanderer
The one on the trunk, or the outer left taillight?
Old Nov 25, 2005 | 08:24 AM
5speedonly's Avatar
5speedonly
What do you mean? It's the left one! Not the high mount, if that's what you meant. It's an 02 Civic EX.
Old Nov 25, 2005 | 08:30 AM
1995Civic's Avatar
1995Civic
I hate ricers
There is an inner and outer tailight on the left side and right side. Which one is it?
Old Nov 25, 2005 | 09:09 AM
5speedonly's Avatar
5speedonly
Inner and outer ?? ***** I don't know dude ... picture me hitting the brake and the left brake light doesn't come on. There is 3 bulbs on each side, even though "haynes" manual describes 2 only "the upper bulb holder is for the brake/ tail/ rear sike marker light bulb" The manual describe the upper as the brake light also. It's a manual. maybe you guys describing an auto rear light?
Old Nov 25, 2005 | 04:07 PM
1995Civic's Avatar
1995Civic
I hate ricers
First of all, get a helms.
Second, pop your trunk and lift it all the way up. Notice how there is a tailight on your trunk and then there is one on the body panel side? Do you follow?...
Old Nov 25, 2005 | 05:03 PM
randomtask77
Wanderer
Well you didn't specify which model civic you have in your original post. Civics prior to your model civic have lights on both the body and the trunk (hence why the question was asked).
But now that we know what model civic you have maybe someone could probably help you. Could be a faulty bulb. Have your tried a completely new bulb? Maybe the prongs in the socket have become loose?
Old Nov 26, 2005 | 08:13 AM
5speedonly's Avatar
5speedonly
02 Civic 2 door DO NOT have tail lights on the trunk!
Old Nov 27, 2005 | 08:17 AM
5speedonly's Avatar
5speedonly
Okay, now both the left and the right not working. It happened while trying to fix it!! All I did was pulling both bulbs out and put them back in . I didn't even pull the right one(the previously working) from it's bulb holder. What possibly went wrong????? I had few friends with me at the time, they said could be the fact that I was not supposed to touch the bulbs by hand?? Seriously, all I did is pulling the socket (or the bulb holder) out and put it back in!!! I didn't even touch the bulb. What in the world could've possibly happened ???? I checked all the connectors and the fuses and they seem to be fine.
Any suggestions ??
BTH this is an 02 civic EX. There are two body style, one whith the brake light on both the trunk and the body. The others have the brake light (all the lights for that matter) in the body only. The latter is mine.
Old Nov 27, 2005 | 10:50 AM
1995Civic's Avatar
1995Civic
I hate ricers
Dont fucking yell at me dude. Not my problem you didnt specify what year civic you had. Good luck, cause i aint helping you.
