JDM Type-R ecu vs. JDM B16 ecu
Old Nov 20, 2005 | 03:06 PM
rampage918's Avatar
rampage918
Default JDM Type-R ecu vs. JDM B16 ecu
I have a JDM B16, which one should I use or does it even make that big of a difference.
Old Nov 20, 2005 | 03:20 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Use the correct one for your motor...JDM b16. Only use different ecus from stock if they are chipped for your setup, or needed for a fuel management system ie hondata.
Old Nov 20, 2005 | 03:26 PM
1995Civic's Avatar
1995Civic
I hate ricers
Agreed.
Im not about all those ECU chips where it changes your vtec timing, and rev limiter. All those do is ruin your motor. Like Tx said, you only need it if it's running your fuel mgmt, or something alike.
Old Nov 20, 2005 | 03:32 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
If you want a b16 ecu let me know i have one...
Old Nov 20, 2005 | 03:38 PM
rampage918's Avatar
rampage918
I have both ecu, I'm going to sell the Type-R one becuase I want to run the correct one now. My b16 ecu is obd1 and the car is obd2, if I buy the conversion harness should I have a check engine light?
Old Nov 20, 2005 | 03:41 PM
bambbrose's Avatar
bambbrose
nope with a conversion harness you should be good to go
Old Nov 20, 2005 | 06:27 PM
rampage918's Avatar
rampage918
Do you think by using the B16 ecu the car should run better?
Old Nov 20, 2005 | 06:55 PM
bambbrose's Avatar
bambbrose
yes, because thats what it was designed to run on
