stupid problem...
Old Nov 6, 2005 | 06:47 PM
bega's Avatar
bega
Default stupid problem...
I got a stupid problem with my civic. When I'm in any gear (rolling) and I floor it, it first stutters (feels like I'm just starting out and the car starts hopping) then when the RPM's increase the problem dissapears. I changed the TPS, but the problem didnt go away. Help anyone? Thanks in advance!
-Sanjin
Old Nov 6, 2005 | 06:53 PM
junior-ae's Avatar
junior-ae
When you say you're rolling, are you rolling at 2 mph, or 30? When you say "high RPM," what do you mean? When you stomp on it at first, and you say you're rolling, does that mean your clutch is engaged, you're rolling at a low speed, and your RPM's are around 1000? Need more info.
If I'm rolling along at a very low speed (~5mph) and my RPM's are around 1000, and I'm in 2nd gear when I decide to stomp on it, my car stutters too. That's too low an RPM and speed range for your car to expect to be able to do anything in any gear other than 1st, so there's just no power to accelerate; i.e. the car stutters. This is normal.
You also say you replaced the TPS. Does that mean you replaced the whole throttle body? TPS's can't be replaced without changing the whole thing.
Old Nov 6, 2005 | 07:00 PM
bega's Avatar
bega
for example 2nd gear at 30mph, clutch is engaged yes, and it usually does it below 4000rpm's. Yes whole throttle body. I said TPS because thats what I read online, 95% of the time its the TP sensor.
Old Nov 10, 2005 | 07:32 AM
APEXi's Avatar
APEXi
im having the same problem dude......
Old Nov 10, 2005 | 07:34 AM
bega's Avatar
bega
I dont think my tp sensor's voltage is right.
Old Nov 10, 2005 | 09:53 AM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
Any Check engine lights?
Old Nov 11, 2005 | 12:12 AM
2000CivicSi's Avatar
2000CivicSi
So you and cruising and you step on the gas and it kinda studders or boggs down and doesn't want to go then it finally kicks in a goes??
I had a similar problem but when I had my catback put on I found out my cat was plugged and it was restricting the airflow. Once I changed my cat it was all running fine then. If its not along those lines...don't know what else to say...
Old Nov 11, 2005 | 08:13 AM
Jafro's Avatar
Jafro
I'm made of meat!
Do a tune up. Sounds like an ignition issue to me. Make sure your plugs are gapped right. If it still does it afterwards, check your base timing. If that's right, unbolt your cat and take a drive & see if that fixes it.
Old Nov 13, 2005 | 09:32 AM
bega's Avatar
bega
heh, the cat is the problem lol, I unbolted it, and it runs fine, you have no idea how releaved I am now...
