B18b for more Horses
When i get my B18b whats a good way to build up the horses before the turbo.... any sugestions....Not looking to rebuild the entire engine but a few bills here and there to bring that sucker up
If you're going turbo later, there's nothing you can do before the turbo that will gain power.
intake manifold and throttle body will help with NA and turbo systems.
LSD for the trans will help a ton. Umm... thats about all I would do |
u could do some head work, cams aside. stock b18b cams are excellent for turbo setups. im probably going to keep mine and upgrade to tit. retainers, dual valvesprings, nitride coated valves, minor P&P and all new seals, valve guides, etc. power is made in the head
a comletely agree with you. The the LS head is where most work is needed if high hp numbers are wanted |
well whats the best head to put on the b18b then? or is it simply better to send it to a machine shop
the b18b head is fine, its just better to build it for more power. or u could go with a b18c1, or my personal favorite, put a b16 head on a b18 block
If you really wanted to you could put the b16 head on like eric said, but that would require the purchase of the golden eagle ls/vtec conversion kit, and some machining and tapping dowells, blah blah. I'm waiting for the whole unreliability thing to pop up now.
ill be the first to say that it is reliable if done right. such as having the block and head both decked and using new seals, gaskets etc. the people that throw them together in an evening are the ones that say "the ls/vtec is dumb and unreliable" well, what do u expect when u throw it together without doing it properly
