how hard is it to install a camber kit?
Old Oct 26, 2005 | 11:31 AM
97civic97's Avatar
97civic97
Default how hard is it to install a camber kit?
Is it possible to do it myself? I never installed anything on a car before, I dont even do my own oil change, but is it possible?
Old Oct 26, 2005 | 11:53 AM
JoshJ's Avatar
JoshJ
bang bang.
id search on here and on other sites for a walkthrough...
IMO, its not hard, however, ive installed everything on my car and done all maintenance myself, everything except for alignments.
if you have the right tools and read over the walkthroughs i think you could do it.
Old Oct 26, 2005 | 12:12 PM
Wharbone's Avatar
Wharbone
I used WCS's DIY when I installed my omni front camber kit. It was easy.
Old Oct 26, 2005 | 01:17 PM
97civic97's Avatar
97civic97
sweet, bc this guy at autozone was like "its gonna be damn hard to install a camber kit." Anyway, thanks. bty, is there a big difference between expensive and cheap kits? Dropzone kits on ebay are $170 for both front and rear while like skunk2 goes for about $300. SHould i buy the dropzone kit?
Old Oct 26, 2005 | 01:30 PM
CA VTEC Sol's Avatar
CA VTEC Sol
get the omnipower kit, it's the same design as the skunk2 but slightly improved, i've had mine for almost a year now and it hasn't given me any troubles. i also got mine for $160ish and i wouldn't recommend any other kit.
Old Oct 26, 2005 | 01:51 PM
97civic97's Avatar
97civic97
there arent any on ebay. as long as dropezone arent made to break or anything, I think those are the ones im going to get.
Old Oct 26, 2005 | 02:22 PM
Wharbone's Avatar
Wharbone
I'd go with the omni's as well. I previously had ingalls style ones that rusted and squeaked a lot. The omni's are much easier to adjust the camber on also.
Old Oct 26, 2005 | 05:24 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
:stupid:
mine have held up fine for the past year, 20-25k miles
install wasn't hard, but we don't get rust problems down here. colder climates might require more grunt work.
Old Oct 26, 2005 | 10:17 PM
syclone's Avatar
syclone
if you need a walk through, you can use my diy.. although, if you've never worked on a car, this could be a challenge for you..
http://syclone.motocrew.com/EJ6/index.htm
Old Oct 27, 2005 | 05:48 AM
Running925's Avatar
Running925
Your Powder Coater
cake job.. get an alignment afterwords!
