Del Sol Problem
Old Oct 14, 2005 | 12:48 AM
dr_liver_bones's Avatar
dr_liver_bones
Default Del Sol Problem
Ok I have a problem with my Del Sol SI. The odometer and the RPMs work fine but the damn speedometer won't work at all unless its a long trip and even then the heat has to be on and its still about 15 mph off. If you have any advice or if you know what would help please tell me.
Thank you in advance for your help.
Old Oct 14, 2005 | 03:27 AM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
check your speedometer cable, you might need to put a new one on.
Old Oct 14, 2005 | 08:14 AM
dr_liver_bones
thanks man do you know if there might be anyother way to fix it. cause i need to try all my possibilities this weekend
Old Oct 14, 2005 | 11:18 AM
qtiger's Avatar
qtiger
Did you mess with the needles on your gauge cluster or install some indiglos or something?
There's no way the odo can work and the speedo not work.
Old Oct 14, 2005 | 08:38 PM
dr_liver_bones
no man i havent done anything to the gauges thats why its fucking me over so badly. cause everything else works... its just the speedometer.
Old Oct 15, 2005 | 11:18 AM
dr_liver_bones
ok so i was wrong.... nothing new for me but what the hell i never really look at the odometer very much. it works but not that much.... pnly after the car warms up a little bit. so is it possible that it might be a fuse or is there something worng with the gauge cluster?
Thanks for the help, again.
