Ok, I just took my car out for the 1st time since I did my clutch....
Old Oct 8, 2005 | 08:32 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Default Ok, I just took my car out for the 1st time since I did my clutch....
Should it make noise since its brand new, never been driven? It's kind of a slight whirring noise, hard to explain.
Old Oct 8, 2005 | 08:39 AM
CaliDELSOL93si's Avatar
CaliDELSOL93si
Yup. it will be like that for the first 150 - 200 stop and go miles. My stage 1 did the exact same thing.
Old Oct 8, 2005 | 08:40 AM
CaliDELSOL93si
scared me half to death but it will wear down factory shit they put on it to loob and it will be fine. what type of clutch ?
Old Oct 8, 2005 | 08:43 AM
Omniscient's Avatar
Omniscient
Exedy stage 1 organic and fidanza flywheel.
Old Oct 8, 2005 | 08:45 AM
CaliDELSOL93si
Nice setup, i had the exact same exedy stage one. what type of hp u pushing ? and it will feel wierd for the first few days....it's normal...
Old Oct 8, 2005 | 09:03 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Did you have to adjust the pedal height?
I remember on my car when I installed the HDSS, the engagement was right at the floor, so it had to be adjusted extensively. Did you also lube the shit out the throwout bearing and the shaft that it slides on?
Old Oct 8, 2005 | 09:10 AM
Omniscient's Avatar
Omniscient
I greased the bulb that the fork sticks to, then I lubed the shaft, and the plastic interior of the throwout bearing that slides on the shaft, I didn't actually lube the internals of the bearing with the balls and cage.
And nah I didn't have to adjust the clutch it's stiff though.
Old Oct 8, 2005 | 11:01 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
I got a wirring noise when I replaced the stock clutch. A year later (40K) the tranny went at 300K. don't know if that'll help you. When I look at the numbers, I'd say you're fine!
Old Oct 8, 2005 | 11:03 PM
Omniscient's Avatar
Omniscient
The noise went away after like 30 miles.
Old Oct 10, 2005 | 11:35 AM
Ctrld-Kaos's Avatar
Ctrld-Kaos
i need a wrench wench
yeah when i replaced the cluch in my ef, it made the same noise. however, the noise never went away and the clutch blew on me after 1000 miles. it was an exedy stage 1 aswell, go figure..
