Do i need to pull the halfshalft to pull the tranny out?
Old Sep 30, 2005 | 11:27 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Default Do i need to pull the halfshalft to pull the tranny out?
Well, Everything's pretty much ready to go, I was just wondering if I need to take out the half shaft to get the tranny off.
Old Sep 30, 2005 | 11:28 AM
Running925's Avatar
Running925
Your Powder Coater
yes!
Old Sep 30, 2005 | 11:32 AM
Omniscient's Avatar
Omniscient
Fuck. Now how do I do that?
Old Sep 30, 2005 | 11:36 AM
Running925's Avatar
Running925
Your Powder Coater
refer to WCS's write up that's in the sticky area or follow these instructions!.
1. remove 32mm axle nut in the center of your hub assembly
2. pound center of axle out of the center of the hub assembly without destroying the threds!
3. remove lower control arm nut (pull cotter pin first)
4. use pickle forke to pop assembly up
5. swing entire assembly out of the way while u remove axle from hub assembly
6. take screw driver & slide between tranny & axle bulge, tap until u see axle pop out a lil bit.
7. slide axle out!
Old Sep 30, 2005 | 11:39 AM
Omniscient's Avatar
Omniscient
I know I took both axles off, but its the half shaft, aka intermediate shaft. The thing inbetween the drivers side axle and the tranny, Does that just pop out too?>
Old Sep 30, 2005 | 11:40 AM
teg92's Avatar
teg92
WHAT OK YEAH!
the halfshaft is held on by 3 14mm bolts on the block they are farley easy to get to
Old Sep 30, 2005 | 11:41 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
There are three bolts that connect it to the block. Remove these and then pop the halfshaft out. Theoretically, you could remove the tranny without pulling the halfshaft as long as you remove those bolts first.
Old Sep 30, 2005 | 11:48 AM
Running925's Avatar
Running925
Your Powder Coater
didn't realize u were talkin bout the intermediate shaft.. my bad.
u can split the motor/ tranny without removing that but it's easier if u take it out..
3 bolts that go into block
Old Sep 30, 2005 | 11:51 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
I was sure it didnt need to be touched at all, just pop the axles out from it
Old Sep 30, 2005 | 12:32 PM
bambbrose's Avatar
bambbrose
removing it makes it a shitload easier to align the tranny back up when putting it back on. It just gets in the way.
