2000 Civic ex Left front blinker problem.
Old Sep 29, 2005 | 05:09 PM
ccmcjones's Avatar
ccmcjones
Default 2000 Civic ex Left front blinker problem.
I know this is my 1st post... But thats not the point...
My left front blinker doesnt work. I tried replacing the light and it still doesnt work.. I even checked the fuses and It says theyre all good... Anyone Know what the problem could be?
Old Sep 29, 2005 | 07:33 PM
1995Civic's Avatar
1995Civic
I hate ricers
Did you make sure the connection is good to the light? Sometimes my plug would "move" around a little bit from vibration, and cause it to go out. It wont hurt to double and even triple check everything. good luck
Old Sep 30, 2005 | 12:39 PM
97civicEXVTEC's Avatar
97civicEXVTEC
when you put ur turn signal on, does it blink fast? faster then the other one?
Old Sep 30, 2005 | 01:23 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i would try replacing the whole socket, that could also be an issue.
Old Sep 30, 2005 | 04:41 PM
AccordCB7's Avatar
AccordCB7
90-93 Accord Owner
You can also try to see if the "Turn Signal Relay" is good.
They tend to go bad, so dont forget to check that also.
It is located under the dash "Driver Side kickpanel"
Old Sep 30, 2005 | 05:57 PM
flatliner's Avatar
flatliner
Fix It
depress you hazard button violently sever times (like 20) and try again. if it dont work goto step a.
