clutch slave?????
Old Sep 28, 2005 | 09:02 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Default clutch slave?????
I recently put a b18 in my 1992 civic and bought a new clutch and slave cylinder. i drained to slave properly. How long will i have to pump my clutch til it goes back to its normal feeling???? Thanks
Old Sep 28, 2005 | 09:46 AM
JETSPD1477's Avatar
JETSPD1477
O RLY?
gotta bleed it like brakes. might take a while but you'll eventually get there.
Old Sep 28, 2005 | 11:50 AM
Omniscient's Avatar
Omniscient
warm butter on toast
When I did my swap, my clutch pedal stuck to the floor, so I had to bleed it, it took about 10 minutes to get it stiff again.
Old Sep 28, 2005 | 12:38 PM
jdmeg6hatchy
i
did you hook it back up then continue to pump it over and over?
Old Sep 28, 2005 | 12:55 PM
JETSPD1477's Avatar
JETSPD1477
O RLY?
it's just like brakes. you need someone to man the pedal or the bleeder valve. one person opens the bleeder on the slave the other person depresses the clutch pedal... close the bleeder valve and release the clutch pedal. this may take a few tries but you'll eventually get there. if you have one of those brake bleeder kits with the check valve you dont need an extra person and it'll get done a lot faster.
