custom exhaust
Old Sep 21, 2005 | 08:06 PM
importkustoms00's Avatar
importkustoms00
Korean DOOD
Default custom exhaust
when constructing a custom exhaust system what actually is reponsible of the deepness of the sound when it is complete. pipe diamater (2.25 vs 2.5), muffler type (n1 style vs canister type vs evo), or resonator or none. i was thinking 2.25 with a actual greddy evo muffler and no resonator. bad or good decision.
Old Sep 21, 2005 | 08:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The resonator will be the biggest factor in how loud an exhaust is. Anything that disrupts exhaust flow will quiet it down: turbo, resonator, cat, etc.
Old Sep 21, 2005 | 08:27 PM
importkustoms00
Korean DOOD
u think it will be too loud with the setup i was thinking about or should i go ahead and get the resonator as well and if so how long should it be cause i know that they make diff sized (length). does 270 sound high for the setup?
Old Sep 22, 2005 | 07:32 PM
importkustoms00
Korean DOOD
anybody?
Old Sep 22, 2005 | 08:35 PM
importkustoms00
Korean DOOD
Old Sep 22, 2005 | 08:41 PM
Provocateur
On permanent hiatus
I wouldn't do it.
If you live in an area where cops give half a damn about noise pollution, they will be all over your ass like flies on dog shit. Also, you will get annoyed with how loud and annoying it is.
You either want to add a resonator or a chambered muffler to that setup.
Old Sep 22, 2005 | 08:44 PM
importkustoms00
Korean DOOD
Originally Posted by Däs Schmoo
I wouldn't do it.
they make 14",18", & 22" long resonators. should i go with the 18"?
Old Sep 23, 2005 | 05:55 AM
Running925's Avatar
Running925
Your Powder Coater
mine used to be
Turblow - 2.75in. pipe (WAY to loud)
Is Now
Turblow - 2.75in. pipe - ES Oval (Nice deep & quiet, i lub it! )
Old Sep 23, 2005 | 06:03 AM
Jafro's Avatar
Jafro
I'm made of meat!
In your first post, you mentioned the "deepness" of the sound, and if a low pitch is what you're looking for, then BIG pipes are where you get it. Anything that increases your exhaust system's internal volume will lower its pitch. You can sacrifice performance with a low-pitch if you can't move your exhaust quickly enough through it because the pipes are too big. Honda motors are fuel efficient because they're very restricted. Too big of an exhaust system may work against you if it's not done properly.
I have 3" pipes on my car because it flows over 680cfms. It's a 2.0L DOHC with enormous intake/exhaust ports on the head and racing cams. In addition to that, I've ported and polished everything on this engine extensively. I need 3" pipes. If you haven't spent $5000 on forced induction modifications already, don't go bigger than 2.5".
Old Sep 23, 2005 | 06:06 AM
Running925's Avatar
Running925
Your Powder Coater
well stated!
