93 civic brake lights don't work
Old Sep 12, 2005 | 06:02 PM
dawgking's Avatar
dawgking
Default 93 civic brake lights don't work
has anyone ever had problems with a 93 civic dx where the brake lights did not work but everything else works (all running lights). there is no power at the brake light switch on either side and i can't find a fuse that works the brake lights. is there an in line fuse or a relay that works the lights?
Old Sep 12, 2005 | 10:01 PM
Wharbone's Avatar
Wharbone
Does you horn work? In the fuse box under the hood, Fuse #42 is for "Horns, Brake system". It is a 20 A fuse.
edit: It could also be the brake light switch attached to your pedal.
Old Sep 13, 2005 | 03:38 PM
dawgking's Avatar
dawgking
I'll try that thanks, but i did check all fuses and they were all working. will check again.
Old Sep 13, 2005 | 06:34 PM
dawgking's Avatar
dawgking
Default it worked
Thanks for the info. i did not have a fuse in that slot and the legend on the fuse box was gone when i got the car. just replaced the fuse and all is fine. again thanks
Old Sep 13, 2005 | 11:21 PM
Wharbone's Avatar
Wharbone
No prob. Glad you got it fixed.
Old Jan 9, 2012 | 06:06 PM
bman95dx's Avatar
bman95dx
Your reply to this post fixed my brake light problem in less than 10 minutes. Thanks Wharbone.
Old Jan 10, 2012 | 06:25 AM
gkjhnrtund's Avatar
gkjhnrtund
Old Jan 30, 2012 | 08:04 PM
bman95dx's Avatar
bman95dx
Dang....new fuse blew again. 2nd time in 2 weeks. Guess I'll be tracking down a short. Not looking forward to this.
Old Feb 17, 2012 | 02:50 PM
Kadzula's Avatar
Kadzula
Maybe you are using the wrong size fuse?
