I got a serious suspension problem, please help
Old Aug 23, 2005 | 06:46 PM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
Default I got a serious suspension problem, please help
I need to change out the old E.S. bushings that I put in previously for some new ones cause there worn. The problem is is that when I worked on the first lower control arm, I got every bolt off but that one bolt that goes throught the control arm into the cross-member would not come out. It just kept spinning. What do you think can be the problem and what should I do. I ain't trying to swap out no cross-member.
Old Aug 23, 2005 | 06:48 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
that bolt is the hardest one to line up, I usually use a scissor jack for that.
Old Aug 24, 2005 | 01:23 AM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
Anyone?
Old Aug 24, 2005 | 02:06 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Did u strip it when u put the LCA in last time??? that is what its sounds like happen.
Old Aug 24, 2005 | 04:45 AM
pinkys43's Avatar
pinkys43
that bolt is hard as fuck!!!! i used a jack and a ball joint breaker to get it off, along with some liquid wrench
Old Aug 24, 2005 | 08:53 AM
NeverBX's Avatar
NeverBX
it keeps spinning because its not grabbing, the bolt itself is pointed at the tip with no threads, it only grabs if it is perfectly lined up. Like I said in my frst post use a scissor jack.
Old Aug 24, 2005 | 07:22 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
hes talking about taking it out, not putting it in.
it might be stripped. try hitting it with a hammer or wrench from the other side and turning it at the same time.
Old Aug 25, 2005 | 12:15 AM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
You can't hit it from the other side because the other side is in the crossmember.
Old Aug 25, 2005 | 09:16 AM
NeverBX's Avatar
NeverBX
last time I tried to take it out I had to use a flat head and pry it while I turned it.
