checking cel
Old Aug 8, 2005 | 07:20 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default checking cel
i was looking through other threads about how to check ur cel.. i found one in the integra forums i jus cant find the thing that houses the wires that need to be connected.. this was from he other thread:
"On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires. "
is it any different because i have a civic??
Old Aug 8, 2005 | 07:31 PM
mini-me civic's Avatar
mini-me civic
if ur car is an OBDII u cant use the paperclip trick... u have to get a scanner or take it in to a shop...
Old Aug 8, 2005 | 07:37 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Wrong, the paperclip trick is how you do it with all of them.
Look in the online resources sticky at the top of this section. It has a DIY with pics on how to accomplish this.
Old Aug 8, 2005 | 07:41 PM
mini-me civic
4realz.. i thought i read somewhere that 96 and up u cant do it... I cant find the wire on my car also on my car.. i have a 96 civic..... do u know where it is located on my car...
Old Aug 8, 2005 | 07:50 PM
97civicEXVTEC
alright the paperclip trick does work.. i checked it and got code 14: IAC Vavle??
should i jus clean my IAC valve.. that could also be responsible for my retarded idle..
Old Aug 8, 2005 | 07:55 PM
97civicEXVTEC
i have a 97 civic.. under the glove box on the passanger side its behind the kick panel ( the panel if u r loooking at ur door, to the left under the dash) youll see a green rubber thing with 2 wires going into it.. pull the blue connecter(that the wires are connected to) out of the green holder. unbend a paperclip and use the 2 ends and stick them into the connecter ( to make a connection between the wires) hint: i used a wire fork from my amp hook up kit..
use this> http://www.c-speedracing.com/faq/06.php
Old Aug 8, 2005 | 08:57 PM
mini-me civic
ur right.... it does work i jusst did mine and got a code 41.. sorry bout dat the gree thing was behind the ecu and i couldnt see it witout a flash light...
Old Aug 8, 2005 | 09:18 PM
97civicEXVTEC
code 41 is primary o2 sensor error fyi
