HX Rims ON EG Si
Old Aug 7, 2005 | 01:40 PM
Frosty7126's Avatar
Frosty7126
Default HX Rims ON EG Si
will HX fit on my eg si?
i read that folks dremel the calipers or used spacers to fit. some said that it was a direct bolt on. ideas?
Old Aug 7, 2005 | 02:57 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
si abs or non-abs
Abs, you may have to use like a 5mm spacer (dont grind...thats silly)
Non-abs you have smaller brakes (dx/vx/cx) so they will bolt up no prob.
Old Aug 7, 2005 | 03:29 PM
Frosty7126's Avatar
Frosty7126
umm wouldnt know if it had ABS on it. i thought it came standard with it?
got a pic of what the ABS unit looks like?
Old Aug 7, 2005 | 03:56 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
the ABS unit should be located next to the intake box, kinda looks like a really complicated brake master cylinder.
Old Aug 7, 2005 | 05:22 PM
PDiggityDogg
Some si's had abs, some didnt.
If youve got 2 boxes w/ a mess of hardlines coming out w/ orange elecrical connectors, you have abs. If your dash says ABS when you turn it on, you have abs. If your si's brake rotors are 10", you have abs.
