gimme boost
Old Aug 6, 2005 | 07:44 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default gimme boost
i have a d16 with 150k miles and am thinkin about putting a turbo on it.. i prolly can only go low boosts with the high mileage on the engine tho so what can i put on to let me boost higher?
Old Aug 6, 2005 | 07:46 PM
VTEC-Power's Avatar
VTEC-Power
Build your internals
Old Aug 6, 2005 | 07:56 PM
97civicEXVTEC
would i need to get new axels if i boost around 9-10?
Old Aug 6, 2005 | 08:01 PM
VTEC-Power's Avatar
VTEC-Power
na stock ones should be fine and you can run 8-10psi on stock internals
Old Aug 6, 2005 | 08:11 PM
97civicEXVTEC
even with the higher mileage?
Old Aug 6, 2005 | 08:14 PM
raiden571's Avatar
raiden571
turning u inside out
do a compression test
Old Aug 6, 2005 | 08:17 PM
VTEC-Power's Avatar
VTEC-Power
Hondas have strong motors and yea do a compression test
Old Aug 6, 2005 | 09:24 PM
2gr84u's Avatar
2gr84u
2gr84u
yea the milage really doesnt matter so long as your compression test comes back with some healthy numbers. You can easily throw 10psi at it with a smaller turbo. these sites will provide you with any and all answers you may be looking for, provide the means to research a turbo setup before you get into it.
www.homemadeturbo.com
www.turbod16.com
www.hondatech.com (has a good forced induction area)
Old Aug 6, 2005 | 09:35 PM
extensioncordy's Avatar
extensioncordy
EG6
but its always best to rebuild a motor b4 you turbo unless its a fresh rebuild or a low mileage engine...rebuilt it now and then you can boost more in the future
Old Aug 7, 2005 | 08:47 AM
raiden571's Avatar
raiden571
^why? if his compression is fine, then boost it.its a d motor, not a b. u can go to the junkyard and pick up another for less then 400 bux. boost, it, beat it, love it.
