can a worn clutch affect starting...
Old Jul 22, 2005 | 07:49 PM
mini-me civic's Avatar
mini-me civic
Default can a worn clutch affect starting...
when i try to start the car all the lights turn on but the engine does not crank.. so i press the clutch pedal twice then the car starts up...i know my clutch is worn and it needs to be replaced... idk... sometimes the car starts up no problem and somestimes i have to play with the ignition... weird...
Old Jul 22, 2005 | 09:06 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Is the car in gear when you try to start it?
Old Jul 22, 2005 | 09:10 PM
mini-me civic
no..i usually start it at neutral..
Old Jul 22, 2005 | 09:16 PM
westcoaststyle
The mechanics of the clutch then would not effect the starting of the car. If it doesn't even try to start and you are quite sure that it has something to do with you pressing the clutch pedal then I'd look into the wiring/sensor at your clutch pedal as there is a switch there that sees that the clutch is pressed in before it will allow the engine to start. Something to consider.
Old Jul 22, 2005 | 09:17 PM
mini-me civic
thanks... imma check that out...
Old Jul 23, 2005 | 05:02 PM
foot's Avatar
foot
I concur
