Transmission axle seal question
Old Jun 24, 2005 | 02:54 PM
OblivionLord's Avatar
OblivionLord
Default Transmission axle seal question
The seal that is in the transmission where the driver side axle goes into is cracked. Its just a very fine piece of rubber nothing much. I don't exactly know if by trying to grab it and take it out by force is ok since I've never done it but, is this the correct procedure?
Old Jun 24, 2005 | 09:50 PM
flatliner's Avatar
flatliner
Fix It
its ok, just remember do not scratch the transmission, if u do apply the new one with sillicone around the mating surface of the tranny/seal not seal/axle./
Old Jun 25, 2005 | 04:22 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you might need a flathead screwdriver or something to pry it out. Ive done this before and they dont come off that easy. let us know how it goes
Old Jun 25, 2005 | 06:00 AM
foot's Avatar
foot
Yes. you have to use a tool to get behind the seal and pull it out. You can destroy the seal, that is ok. But, don't scratch the transmission. If the scratch is bad enough you will have a permanent leak.
Old Jun 25, 2005 | 11:17 PM
flatliner's Avatar
flatliner
Fix It
I always used to in the ol school days run a screw in the soft prt and then pull it from the screw, I would just manhandle it and make it come out.
Old Jun 26, 2005 | 08:32 PM
OblivionLord
I did it with a flathead, took it out, went to honda to buy the new one and put it in. ALl is well now.
