Welp.. time for a radiator, got any ideas?
Old May 29, 2005 | 06:56 PM
jweltch's Avatar
jweltch
Closet Ricer
Default Welp.. time for a radiator, got any ideas?
Back in January I replaced my waterpump, hoses, t-stat, and put a better cap on the rad. Since the car has 153k mi, I knew my radiator was the weakest link in my cooling system but kept putting it off. Well, it's now leaking at the seam between the core and top tank.
I could easily just put an OEM replacement in there, but was curious if there was anything bigger/better that will just drop in. I did some searching and found that a Del Sol radiator is close, but will it just drop in with all my original hoses?
Old May 29, 2005 | 07:25 PM
Nelson's Avatar
Nelson
Administrator
Dual Core Del Sol radiator is cheap and effective.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 29, 2005 | 07:30 PM
jweltch's Avatar
jweltch
Closet Ricer
Will it bolt right up without any A/C or other clearance issues? Hoses?
Old May 30, 2005 | 01:22 AM
Green Fastback's Avatar
Green Fastback
PT-5doors
this is not mine but ists a niçe ideia for improve your cooling systems
File Type: jpg
Old May 30, 2005 | 08:07 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
you'll want to get b-series hoses along with the del sol dual-core. The stock hoses are a little to skinny to fit over the new radiator's inlet/outlet. You'll also need to be sure you clamp them down real tight on the motor side since the diameters of the water inlet/outlet on the motor dont quite match up with the inner diameter of the larger hose. Some people wrap the inlet in duct tape or electical tape to create a better seal, but I'm not sure I'd want to do that to my car :thinking:
Old May 30, 2005 | 01:29 PM
FATHONDA's Avatar
FATHONDA
i would just get a oem style radiator unless you have some silly psi boosting gadget.
Old May 30, 2005 | 06:16 PM
Paulll's Avatar
Paulll
Hail Bent
mmhmm
Old May 30, 2005 | 09:11 PM
bambbrose's Avatar
bambbrose
You can get the regular civic radiator from an Auto civic and its also Dual core, but just stock half length, it's also bolt in. It's not a lot bigger than stock, but it's better than nothing.
I'm assuming you have a 5speed here. if not, then your only choice is teg, del sol, or aftermarket I think
Old May 30, 2005 | 10:02 PM
jweltch's Avatar
jweltch
Closet Ricer
Originally Posted by bambbrose
del sol is dual core and full length.
Yeah, it's a 5-speed. This is what I ended up doing. Autozone special with a lifetime warranty... can't bitch too much about it, it bolted right in with no issues. It's not a 2 row, but it's definitely thicker than the stock rad. I had to keep the half length due to A/C restrictions.
Old May 31, 2005 | 05:12 AM
bambbrose's Avatar
bambbrose
good to hear. I know a couple boosted people with that radiator and they have no issues
