Quick Help - Fuel Filter
Old May 17, 2005 | 10:39 AM
str8edgexx's Avatar
str8edgexx
Default Quick Help - Fuel Filter
I'm in the process of changing my fuel filter, and I can't get the bottom banjo bolt (attached to the fuel line) off. Any suggestions would be greatly appreciated.
Old May 17, 2005 | 11:05 AM
str8edgexx's Avatar
str8edgexx
bump...I need some help...still no luck
Old May 17, 2005 | 11:19 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Penetrating fluid of some sort. What do you mean? the bolts stuck?
Old May 17, 2005 | 11:25 AM
str8edgexx's Avatar
str8edgexx
the bottom nut on the fuel filter is stuck to the bolt on the fuel line. I've tried using liquid wrench, and its not working. The only thing thats happening is that the fuel line is being twisted
Old May 17, 2005 | 11:59 AM
MPerson's Avatar
MPerson
I had this problem and just said fcuk, it. I'm still waiting to change my fuel filter, so I hope there's an answer coming up!
Old May 17, 2005 | 12:01 PM
Omniscient's Avatar
Omniscient
I just said fuck it and wrenched at it untill it came out.
Old May 17, 2005 | 12:14 PM
str8edgexx's Avatar
str8edgexx
The fuel line got so messed up that I broke it off. Once it was off, I got the banjo bolt out, and I fed the fuel line back through it. Hopefully I won't have a leak. I'll know in a few minutes.
