Question about engine swap?
Old May 8, 2005 | 07:47 PM
dawrenn's Avatar
dawrenn
Default Question about engine swap?
I am planning on getting an ls or GSR engine for my 99 Civic coupe and I was wondering if I have to get a new exhaust system or can I use the one I have on my car now?
Old May 8, 2005 | 08:06 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
You can use the one you have now. Just have a custom length cat made to fit the difference.
Old May 8, 2005 | 08:32 PM
dawrenn's Avatar
dawrenn
Good, I thought I was going to have to get a whole new exhasut system.
Old May 8, 2005 | 09:16 PM
Audz's Avatar
Audz
what kinda exhaust do you have? and do u have any plans on moding the motor?
Old May 8, 2005 | 09:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You may want to think about a wider exhaust to allow the larger engine to breathe better. Not necessary but definitely recommended.
Old May 8, 2005 | 09:40 PM
Audz's Avatar
Audz
^^yea for sure. your going to be pullin in air alot faster and u need to be able to get it out just as fast. increase your piping size and get a different muffler. the car has to be able to breathe.
Old May 9, 2005 | 06:31 AM
dawrenn's Avatar
dawrenn
What would a good piping size be?
Old May 9, 2005 | 07:25 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
just look into an aftermarket exhaust for the civic. have the correct diameter catylitic coverter to match. they all should be around 60 mm in diameter which is fine for the swap.
Old May 9, 2005 | 09:03 AM
Audz's Avatar
Audz
i recommend headerback if u really want the power. and go with 2.25 inch piping. i was running a 2.25 inch apexi N1 catback with a 26inch resonator on my coupe when i had my single vtec, cuz i wanted it quiet.. but now that im runnin ls vtec i kept the piping size but had it mandrel bent, i did headerback instead and removed the resonator. i would recommend something thats mandrel bent like mine, and not welded up. if you have the money then thats your best bet. u get the sound, power, and your car will breathe wonderfully.
Old May 9, 2005 | 09:36 AM
dawrenn's Avatar
dawrenn
I was thinking about getting the HKS Hi-Power exhaust:
http://www.hopupracing.com/hkshiexcisie.html
