Overheating
Old Apr 23, 2005 | 11:00 AM
civicblue4's Avatar
civicblue4
Default Overheating
I have a 93 honda civic 4 dr,and the car over heats when the heating air vent is not on it over heat it has A/C could this be the issue
Old Apr 23, 2005 | 11:36 AM
Omniscient's Avatar
Omniscient
warm butter on toast
The manual that comes with cars usually reccomends turning the heat on when a car starts to over heat. I could be low coolant, air bubbles, bad head gasket, bad water pump, thermostat, or a leak.
Old Apr 23, 2005 | 11:50 AM
civicblue4's Avatar
civicblue4
Thanks i will investigate
Old Apr 23, 2005 | 12:06 PM
Check to see if ur radiator fluid looks milky brownish...if so then it could be a head gasket problem....
Old Jun 17, 2005 | 02:09 PM
clinger17civic's Avatar
clinger17civic
i recomend chaning the auxilary fan switch this solved the overheating problem on my 92'civic si after i changed the thermosdat, rad cap, ect.
Old Jun 17, 2005 | 02:13 PM
Civic2Scooby's Avatar
Civic2Scooby
questions:
a: is the fan coming on, if not then your thermo switch is bad.
b: is the lower radiator hose hot after the car warms up...if it is not, then your thermostat is stuck closed.
c: how many miles are on this car, and when is the last time the thermostat was changed?
d: how does the radiator itself look, is there any buildup, excessive bent fins, bent or crimped coolant passages?
Old Jun 17, 2005 | 10:50 PM
VTEC-Power's Avatar
VTEC-Power
The A/C can cause your car to overheat if you are idling for a long time or going up hills
