Headers: Ceramic vs Stainless/Brushed
Old Apr 5, 2005 | 03:14 PM
imnot4n's Avatar
imnot4n
Dangerously Advanced
Default Headers: Ceramic vs Stainless/Brushed
What type of header is the best for a non-race daily driver type car? I ask this because I've heard pros and cons from friends on all types of headers. Also, what's the difference between the 4-2-1 and the 4-1? Low end and high end hp? THanks to all that respond.
Old Apr 5, 2005 | 03:18 PM
Snoopy's Avatar
Snoopy
been there done that
4-2-1 is geared towards midrange
4-1 for top end
ceramic holds heat in better but the coating tends to crack and peel after a while. stainless wont rust and turns a nice purplish color when heated up.
Old Apr 5, 2005 | 05:44 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I wish I had goten the stainless. My ceramic hasn't cracked yet tho, but it does turn yellow after like 6 months.
Old Apr 5, 2005 | 05:46 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Repaint it with silver BBQ paint. Looks just the same as the CC and it stands up to the heat very well.
This is the shtuff:
File Type: jpg
Old Apr 5, 2005 | 05:57 PM
Omniscient's Avatar
Omniscient
BBQ paint?
Old Apr 6, 2005 | 12:30 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
like :snoopy said...
4-2-1 tends to give midrange gains
4-1 tends to give top end gains
ceramic vs stainless.
there has been many many posts and arguments about this. But this is my take.
performance - SS tends to raise under hood temps but reduce actual engine temps due to it dissipating more heat through the metal and not just in the exhaust gasses.
Ceramic tends to reduce under hood temps but since it's not dissipating the extra heat, it tends to run the engine a little hotter.
appearance - ceramic vs polished, you decide. neither stays that way for long. And yes the BBQ paint trick works, but it dies after a while too.
(Especially with an OEM cat running 7500-8000RPM for almost an hour straight. The header glowed for a long time and there was not much left of the original coat or the BBQ paint. )
price - ceramic is always cheaper since they can hide blemishes and problems with the coating. But the problems may come back to haunt you later.
I went with a SS 4-2-1 because my engine runs hotter than most, I'm less concerned with underhood temps and IMO honda engines need all the midrange help they can get.
Old Apr 9, 2005 | 08:30 PM
padizzill's Avatar
padizzill
i have a question about the dc sport 4-2-1 header
i have herd that the weilds on them arent very good and tend to leak, is that true?
Old Apr 9, 2005 | 08:34 PM
padizzill's Avatar
padizzill
those are the SS
Old Apr 9, 2005 | 08:41 PM
Omniscient's Avatar
Omniscient
I painted mine, sheesh, they look nice.
