I backed up and hit my muffler into the curb
Old Mar 31, 2005 | 05:53 PM
oudi's Avatar
oudi
Banned
Default I backed up and hit my muffler into the curb
now my car is making a funny noise.WHAT DO YOU GUYS THINK IT IS AND WILL IT BE EXPENSIVE TO FIX? iT SOUNDS LIKE IT IS COMING FROM THE MIDDLE OF THE CAR.i F I GET A WHOLE EXHAUST SYTEM WILL IT FIX THE PROBLEM?
Old Mar 31, 2005 | 06:16 PM
the heat shield might be loose but other than that your post is a bit vague. Try removing the heat shield
Old Apr 1, 2005 | 08:49 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
Is it a constant odd noise, or is it an odd noise at certain RPMs? I know my heat sheild has rusted through (live on the coast), and it makes an odd noise at certain RPMs. But if it is just a plain louder sounding engine noise than before, then it could be a hole in the pipe, or muffler... could be a lot of things. If you don't know for sure, just take it to a muffler shop and put it up on the lift. They should be able to tell you without a whole lot of replacing.
Old Apr 1, 2005 | 11:37 AM
swaggs21's Avatar
swaggs21
sounds like the heat shield....
Old Apr 1, 2005 | 01:03 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Might have cracked the piping too or even screwed up the seal from the header collector to the cat. Depends on what noise it is. Can you be more specific?
Old Apr 1, 2005 | 03:30 PM
tukncivic's Avatar
tukncivic
I did the same thing it was the heat shield
Old Apr 1, 2005 | 03:31 PM
tukncivic's Avatar
tukncivic
and it came off the hangers too.
