Tach Install
Old Mar 30, 2005 | 12:31 PM
sleeping_civic's Avatar
sleeping_civic
Default Tach Install
Does anyone have a DIY on how to install an aftermarket tach? I have a 99 civic lx. Any help would be great. Thanks guys.
Old Mar 30, 2005 | 03:21 PM
drew935's Avatar
drew935
Laguna Seca circuit
there's only four wires to hookup.
red- 12+v
blk- gnd
illumination and neg wire on the coil off the distributor.
Look at the helms or fsm for more info. Most likely in a sticky post
Old Mar 30, 2005 | 11:56 PM
Ziken's Avatar
Ziken
RACE USE ONLY
Lookin good Nelson. I'd like to see more pics of the roof spoiler and the visors.
I just installed mine and it was pretty easy.
Black is the ground. just attach it\screw it to any metal part of the body.
The tach wire (color varies to tach) will attach to the tach wire coming from your dash gauge. It should be a light blue wire. Just tap into that.
Red positive wire will need to be powered only when the key is on the on position. So look at your ignition(where you put your key in) There will be a thick yellow wire. Tap into that wire. The white wire or in-dash lighting wire, i dunno where to wire that, so i just wired it into that yellow wire also.
Have fun.
Old Mar 31, 2005 | 01:07 AM
sleeping_civic
Default tach
Thanks for the help guys. Going to get it hooked up this weekend!
Old Mar 31, 2005 | 12:26 PM
Cliff's Avatar
Cliff
i have a 96 dx and there are a couple of blue wires back there? which plug is it on?? left or center?
Old Mar 31, 2005 | 07:05 PM
Ziken's Avatar
Ziken
RACE USE ONLY
if you pull the center guages out(not fully, just pull it out and look over it.) it should be on the left, bottom i think. but its left
