My left turn signal blinks really fast,
Old Feb 28, 2005 | 06:18 PM
96Civic_Coupe's Avatar
96Civic_Coupe
Assistant to the manager
Default My left turn signal blinks really fast,
but my right one doesnt, how do i fix this?
Old Feb 28, 2005 | 06:21 PM
randomtask77's Avatar
randomtask77
Wanderer
Might want to check the bulb and see if one of the filaments is out. Or you might want to check the wiring and see if the ground wire is still intact.
Old Feb 28, 2005 | 06:40 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
usually it means one of you signals is out.
Autocross Help Page
Old Feb 28, 2005 | 07:48 PM
lgbr's Avatar
lgbr
Wal-Mart Shopper
This happend when my front bulb was out.
How can I get it to do this with all the bulbs working? A new thermal flasher?
Old Feb 28, 2005 | 08:39 PM
96Civic_Coupe
also, i have an At and when the car is in park and i press the brake pedal, theres a clicking sound coming from underneath the shift box. why is it doing this?
Old Mar 1, 2005 | 06:27 AM
str8edgexx's Avatar
str8edgexx
Thats the safety switch disengaging that makes it so that you can't take the car out of park without your foot on the brake
Old Mar 1, 2005 | 08:31 AM
speed_69's Avatar
speed_69
don't worry about that..my civic coupe with automatic transmission does the exact same thing..first i thought it was f'd up but now i've gotten use to it
Old Mar 1, 2005 | 10:15 AM
Kabooki's Avatar
Kabooki
there is also a keyhole, so if for some dumb reason it does not disengage when you step on the brake, you can stick the key in there to manually release the button lock.
I actually had to use that a while back. It just got stuck for some reason
Old Mar 1, 2005 | 07:15 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
check ur fuses....
