Which bearings should I replace
Old Feb 11, 2005 | 02:04 AM
sonik's Avatar
sonik
Default Which bearings should I replace
In these 2 pictures what bearings should I replace??? Which one is the input shaft bearing??
Old Feb 11, 2005 | 02:44 AM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
why not have the dealer print out the "Legend" for the numbers.
Old Feb 11, 2005 | 04:08 AM
bambbrose's Avatar
bambbrose
guessing 17, but not sure by any means. If you take the case apart to replace one bearing you should usually replace them all
Old Feb 11, 2005 | 04:59 PM
sonik's Avatar
sonik
first Picture
001 Case, Clutch
002 Plate C, Oil Guide
003 Magnet, Transmission
004 Case, Differential
005 Gear, Final Driven
006 Gear
007 Shim
008 Bolt, Flange (10mm)
009 Bearing, Ball (6205uc/26)
010 Bearing (72x35x17) (ntn Corp.)
011 Bearing (30x47x21)
012 Oil Seal (35x56x8) (arai)
013 Oil Seal (14x25x15)
014 Oil Seal (26x42x7) (nok)
015 Pin A, Dowel (14x20)
second Picture
001 Mainshaft
002 Shaft, Reverse Gear
003 Gear
004 Gear Set
005 Gear
006 Gear, Reverse Idle
007 Gear
008 Sleeve Set (5)
009 Colr (27x34x32x50.4)
010 Washer, Spring (36mm)
011 Washer (26mm)
012 Bearing, Ball
013 Bearing (34x39x23)
014 Bearing (34x39x27.5)
015 Bearing (32x37x23.5)
