Camber Question
Old Aug 22, 2002 | 05:38 PM
matvtec's Avatar
matvtec
Default Camber Question
I need some help understanding the front camber issue. I'm having a -ve camber on my front '92 civic.
What causes it to shift to +ve @ -ve. I mean, which component/s that expand/move that cause this -ve @ +ve camber effect.
Will changing these affected component/s will fix or reduce the -ve camber? I've tried pressing but with little effect. Is there any other way to fix it other than using adjustable front camber kit.
Help is appreciated.
Old Aug 22, 2002 | 06:03 PM
Nelson's Avatar
Nelson
Administrator
You lower your car? If you did, you'll need a camber kit.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 22, 2002 | 06:08 PM
matvtec's Avatar
matvtec
No I didn't, I'm using an Integra Type-R shock/springs currently and the ride is almost the same as stock.
Old Aug 22, 2002 | 06:54 PM
PatrickGSR94's Avatar
PatrickGSR94
I'm not a n00b!
Civics and Integras (before 01) use a double wishbone front suspension, with unequal length upper and lower control arms. As the suspension compresses and rebounds, the control arms move through a range of motion that makes an arc. Since the radii of these arcs is different (shorter at the top), the upper control arm rotates upward more than the lower control arm for any given amount of vertical suspension movement. This makes the wheel take on a negative camber angle as the suspension is compressed (or the car is lowered), or positive as the suspension expands (or the car is raised). This is extremely helpful at keeping the tire's full contact patch on the road through corners, etc, and why Hondas have always been praised for excellent handling straight from the factory.
Unfortunately Honda did not design any camber adjustments, so you have to go aftermarket if you want to adjust and dial it in exactly.
Negative camber is not always a bad thing. Some negative camber will greatly improve the car's handling. My car has what most would probably call excessive camber (about -2.1 to -2.3 deg. all around). However, the toe settings are set to exact specs, and I rotate my tires every 3K-5K miles. After 15K miles my tires are still perfectly even all the way across, no camber correction kits or anything.
I recommend this link to learn more about suspension systems. Click double-wishbone to find out about Honda suspensions. http://autozine.kyul.net/technical_s...htm#Suspension
Old Aug 22, 2002 | 07:08 PM
matvtec's Avatar
matvtec
Thanks for the info, will look at the articles. What I probably will do is to make the left and right front camber equally balanced.
...if u can't beat them..join them....maybe for better I hope.
Thanks again
dhave3
Accord
7
Mar 30, 2005 09:10 PM
19.3secS2K
92+ Civic/EL & Del Sol
24
Nov 19, 2004 03:58 PM
97GS-RPOWER24
11
Jun 15, 2003 08:32 PM
AadosX
Accord
9
May 13, 2003 08:21 PM
G2Integrity
4
Jul 6, 2002 10:40 PM
