Which water pump & timing belt to use?
Old Jan 27, 2005 | 05:52 PM
LA93Hatch's Avatar
LA93Hatch
Default Which water pump & timing belt to use?
Quick questions. Will an integra type r water pump fit on a jdm b16 sirII motor? I need to gather a few parts before i do the swap. Also, should i just buy a honda timing belt or is there an upgrade out there? thanks
Old Jan 28, 2005 | 04:14 AM
wilsel's Avatar
wilsel
I thought all b-series waterpumps are interchangeable. I would stick with a Honda timing belt. There are others out there, but I've read on honda-tech that people have had problems with the aftermarkets.
Old Jan 28, 2005 | 05:24 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Why would you want to put a TypeR pump on the B16? Just get one for the B16 if you're going to get one anyway. I've always used and OEM timing belt. Never had a problem with them.
Old Jan 28, 2005 | 06:07 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Oem
Old Jan 28, 2005 | 05:22 PM
LA93Hatch's Avatar
LA93Hatch
i was once told that the type r water pump flowed better.?? not true??
