Right side tires leaning in, rough ride in the winter w/ low pros
Old Jan 24, 2005 | 03:51 PM
imnot4n's Avatar
imnot4n
Dangerously Advanced
Default Right side tires leaning in, rough ride in the winter w/ low pros
I seem to be having problems with my suspension with my 92 civic dx sedan. My right side tires are leaning in even after the wheel alignment. It has been lowered, how much i dont know and how I don know. I know I need a camber kit. I dont know where to get them and what brand I should use. Also, should I get polyurethane, or rubber. Please help out with any info that you may have. I will post pics in forum by tomorrow.
PS How do you post pics in thread (not thumbnails).
Thanks.
Old Jan 24, 2005 | 04:12 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
host the pic somewhere on the internet... then type in... [ IMG ]put the location of pic in here[ /IMG ] (without the spaces and obviously the location of your pic)
A camber kit will get rid of the lean. I highly recommend the Ingalls kit. I love mine.
Poly is a good idea if you're going to push the car to it's limits, but not if you want a semi-smooth ride on the street.
Old Jan 24, 2005 | 04:51 PM
imnot4n's Avatar
imnot4n
Default pics
Im so determined to fix this problem, I just went out in the 25 degree night and took some pictures. These are the best I can do at night.
Pics in order:
1st thumb - right rear tire (behind)
2nd thumb - right rear tire (behind)
3rd thumb - right rear tire (beside back panel)
4th thumb - right rear tire (above wheel well)
5th thumb - left side car height (about 6 inches) from ground
6th thumb - right side of car height (about 7.5 inches) from ground
More on next reply.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 24, 2005 | 04:52 PM
imnot4n's Avatar
imnot4n
Default more pics
7th thumb - diagonal angle
8th thumb - front (about 7.7 inches) from ground
With the front view, you can obviously see that the left side of the car (right side in the pic) is lower than the other side. Feedback is a MUST at this point.
File Type: jpg
File Type: jpg
Old Jan 24, 2005 | 05:02 PM
imnot4n's Avatar
imnot4n
Default post pic
My first try
Old Jan 24, 2005 | 05:28 PM
teg92's Avatar
teg92
WHAT OK YEAH!
is it just that 1 tire or is it on both sides?
Old Jan 24, 2005 | 06:45 PM
1995Civic's Avatar
1995Civic
I hate ricers
do the washer trick in the back to shim it out and i would recommend either an ingalls front camber kit or a skunk2 kit if you have the money. both are excellent.
Old Jan 24, 2005 | 06:56 PM
oldskoolcivic's Avatar
oldskoolcivic
looks like you need a camber pretty bad before you waste money on buying new tires
Old Jan 25, 2005 | 06:04 AM
teg92's Avatar
teg92
WHAT OK YEAH!
are you sure nothing is bent on the suspension on that side??
