E brake Doesnt Work
My e Brake Doesnt work i pull it up and i just falls right down. I have no idea what could be wrong i have a 92 honda civic dx hatch. could i get help please thanks.
the cables either came loose or the tensioner came off. take off the armrest/center console to check.
Yeah, what they said.
There will be one cable connected to the lever going to a bar which is connected to two cables leading down through the chassis (to the rear wheels). There are screws which will tighten the slack of the two cables. That's how you add tension.
Make sure that the ratcheting latch in the center housing (just under the handle) is working and the spring isn't broken. Also make sure that the button that you press in isn't gummed up with something and held in all the time.
