need help!
Old Dec 13, 2004 | 09:41 PM
ghettoklepto's Avatar
ghettoklepto
Default need help!
im having a spark problem, all of a sudden im not gettin spark i drove 4hrs with my buddy to somewhere and then i had my car idle and it bogged down bc of cold weather and now it wont start it cranks just wont fire i bought new plugs and wires. im guessin distributor just wanted some input
Old Dec 14, 2004 | 02:32 PM
vinnyzcrx's Avatar
vinnyzcrx
have you looked at the distributor? i have had 2 major problems with my distributor in the same senario that you are in. the first time there was no evidence of anything being wrong with the distributor except that it didnt throw a spark, and it wasnt the coil. so i bought a used distributor off of ebay and it started up and ran fine for a while until one day it happened again. except this time it was sputter once every 3 or 4 cranks like it was trying to start. so i opened the distributor and right away a scrue falls out. it was the scrue that fastens the main wheel that makes contact with the distributor contacts for eack spark plug. so none of the spark plugs were getting spark. i recomend opening the distributor and troubleshooting it, if nothing appears wrong check the input power for the distributor to make sure its getting power, if it is, and you still dont get a spark, then replace the distributor. the book will tell you the correct values for the input power
Old Dec 14, 2004 | 03:14 PM
honura's Avatar
honura
Seni
We just had a problem on a 96 It did not wanna throw any spark so we changed the distro and all. and got nothing. We looked at the fuse box in the engine bay and we blow a fuse. Check the fuse box and make sure you did not blow a fuse.
Old Dec 14, 2004 | 11:02 PM
ghettoklepto
got it runnin went to local acura dealership and talked to a technician i was recommended to and he told me check my fuses b4 anything and it was a fuse so i was lucky
Old Dec 15, 2004 | 06:08 AM
honura's Avatar
honura
Seni
Told you! Sometimes the biggest thing is soooooo Small. Hehe Glad you got your car running. Goodluck.
Old Dec 15, 2004 | 06:50 AM
Running925's Avatar
Running925
Your Powder Coater
which fuse was it?
