B16A2 into 95 civic dx! Need Advise!
Old Dec 11, 2004 | 07:59 AM
vinnyzcrx's Avatar
vinnyzcrx
Default B16A2 into 95 civic dx! Need Advise!
im about to do a b16A2 swap into a 95 civic dx. can i use the stock motor mounts, and axles. keep in mind, we have the whole 99 civic si. so would we use the 99 civic motor mounts or the 95 civic mounts? i heard the 99 civic si axles will work? also any other advise would be very appreciative.
Old Dec 11, 2004 | 08:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
the axles will work, but i think there are 2 motor mounts that will Not work
Old Dec 11, 2004 | 03:42 PM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
Kee p in mind that you will need a rear bracket from a 94-01 Integ, I don't think you can use the SI and you definatly can't use the your own.
Old Dec 12, 2004 | 07:37 PM
Nelson's Avatar
Nelson
Administrator
You are telling him that he can use the stock D-series axles on his B-series swap?
Are you sure of this information that you are telling him?
I certainly do not agree.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 12, 2004 | 07:43 PM
Civic2Scooby's Avatar
Civic2Scooby
he ment that you can use the b series axles from the 99si, but not the mounts
Old Dec 13, 2004 | 06:54 AM
vinnyzcrx's Avatar
vinnyzcrx
http://www.ardperformance.com/cgi-bi...c.pl?serial=14
this web site implies that i dont need to buy new motor mounts. is this correct? i need someone that has done this before or who really knows. thanks
Old Dec 13, 2004 | 07:43 AM
Civic2Scooby
ok you will need 94+ integra motor mounts, p30 obd1 ecu, obd1 GSR dizzy, obd1 injectors, 94+ integra rear tranny bracket, 99-00si axles or 94+ integra axles, obd1 wiring harness.
the EK mounts will not work.
Old Dec 13, 2004 | 08:26 AM
teg92's Avatar
teg92
WHAT OK YEAH!
He said he has the whole b16a2 swap including axles so i said that the axles would work, I didnt mean the d series axles
Old Dec 13, 2004 | 09:50 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
it would probably be easier to swap a B16A3 from a OBD1 Del Sol VTEC
Old Dec 13, 2004 | 01:55 PM
vinnyzcrx's Avatar
vinnyzcrx
ok, i have the 99 civic si axles, i plan on buying the obd1 to obd2b wiring harness conversion, i am going to use the 99 civic si ecu, and a motor mount kit. do i need anything else.
