B16A2 into 95 civic dx! Need Advise!
Old Dec 13, 2004 | 01:58 PM
vinnyzcrx's Avatar
vinnyzcrx
some more major question
what is the difference between the obd2b wiring harness from the obd1 wiring harness?
is the 95 civic dx already wired for vtec?
if i bought a p30 ecu would i have to do any other wiring changes for the obd2b b16a2 to work.
Old Dec 13, 2004 | 04:08 PM
teg92's Avatar
teg92
WHAT OK YEAH!
dx isnt vtec
Old Dec 13, 2004 | 04:28 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Originally Posted by teg92
dx isnt vtec
true...but the 1992 (built in japan) ONLY Civics were all pre-wired for VTEC no matter what trim. My DX was pre-wired.
to answer the question...no the 1995 DX will not be wired for VTEC. You'll need to wire that along with a knock sensor if needed. you will also need to see if the 02 sensor wires will need to be converted to 4 prong and you will probably need to add another bung to the header for the secondary 02.
